SC radiator cap questions?
Mike Schwartz
03-07-2004 16:16:53
Hello, after rebuilding the carb I was able to hook the '49 SC to a disc for a while this afternoon. Tractor is missing the rad. cap, currently had the bottom of a pop bottle. After the tractor was warmed up ran some antifreeze out the overflow. Is this a non pressurized cooling system? Does it require the correct cap to cool correctly? It looks like the gas cap and the radiator cap are the same size, can a gas cap be used for the radiator? Is there a source for these caps anywhere? Not looking to spend the $65 for a dealer replacement at this time. Thanks for any ideas, Mike Schwartz(WA)
Mike Schwartz
03-07-2004 19:55:45
 Re: SC radiator cap questions? in reply to Mike Schwartz, 03-07-2004 16:16:53
Thanks everyone, I did not think that it was pressurized, but better to ask than guess I thought. I will try to match up a cap tomorrow. I am pretty sure that the timing is OK, was pulling a 8 foot Killefer tandem disc in wet ground, all the tractor wanted to pull in 2nd gear. Probably the first time that the tractor has had a good load behind it in many years. Thanks again, Mike.
todd hamilton
03-07-2004 18:28:33
Don't fill it too full. Mine has "peed" a couple of times when real hot (pulling out bushes and temp gauge about 210) but there is still coolant at the top frame of the radiator. If it is overflowing you are either too full and/or too hot. I have not put any coolant in my tractor for over four years. Don't ask me about oil consumption!:^)
Mike Schotte
03-07-2004 18:37:29
 Re: Re: SC radiator cap questions? in reply to todd hamilton, 03-07-2004 18:28:33
Hey Todd,
Your tractor has "consumption"? I heard that was a killer disease back in the day... (grin)
-Schotte
todd hamilton
03-07-2004 18:45:53
 Re: Re: Re: SC radiator cap questions? in reply to Mike Schotte, 03-07-2004 18:37:29
I can't tell if smokin' is the cause or the symptom!
Mike Schotte
03-07-2004 17:52:56
F.Y.I. - this may help.
-Schotte
dctom
03-07-2004 16:45:36
mike try 319-523-2805 warren kemper he has them repo, i think cheaper than 65.00 it is not a pressure system should cool fine if radiator is clean check timeing could make it run hot tom
old school
03-07-2004 16:42:51
gas cap can be used and no it is not pressurized. good luck
