Case 730 CK hydrolics ?????
Doug Franks
03-07-2004 13:14:14
I have a 730 CK and the 3 point doesnt want to lift right all the time. It is slow untill it starts to move and then it lifts ok. Sometimes if you work the remote handles a little it will take off and lift. What is causing this ?? Is it something really simple that I'm overlooking?? Any help would be appreciated! Thanks Doug
Brent Behner
03-08-2004 16:30:14
 Re: Case 730 CK hydrolics ????? in reply to Doug Franks, 03-07-2004 13:14:14
Doug Remove Floor Board. Rear Center Of Diff. & Trans. Housing Is Hitch Valve. Small Plate With 4 Bolts Holding Plate To Side Of Valve, Bolts Take 1/2 Inch Socket, Grind Outside Of Socket To Fit Back Bottom Bolt. Remove PlateCarefull Center Ball @ Spring Will Fall Out. Back Valve Remove & Tap Out Domed Pistion, REMOVE LOCK SCREW, REMOVE METERING SCREW & CLEAN HOLE. POLISH OUTSIDE OF VALVE. TURN METERING DOWN ALL THE WAY, BACK OFF 2 TURNS ASSMBLE & CHECK. Front Spool Clean And Polish.Don"t Turn That Screw. Flow Control Valve At Rear Plug Of Control Valve. To Clean Remove ControlValve From Tractor Put Punch In Spring Hole & Un THREAD ThenRemove Plug, Spring & Valve,& Polish Valve.
DKase
03-08-2004 06:08:59
I have the same problem with my 970. There is a delayed reaction of about 4 seconds from the time I move the control lever till it starts to raise. I was hoping someone had a good answer.
