case 400 3pt wont move
tony
03-06-2004 14:10:57
hi everyone. im a newbie. The other day i was plowing with the 400. (there is a blade on the back. and i went up. and it wont go back down or anything. The lever usually goes 8 inches motion. Now it goes all the way to the floor and the seat. There is another lever next to it for like another implement that lever works good. So is there a seal or anything that would have went? Anyhelp would be great thanks tony
Gene Dotson
03-06-2004 20:45:47
 Re: case 400 3pt wont move in reply to tony, 03-06-2004 14:10:57
Is this the original 400? If it is, it sounds like the shaft into the control housing has broken. There are 2 shafts, one inner and an outer. They have fingers on them to operate the valves. The inner, solid shaft controls the lift arms. Remove the plate on the back and watch to see of the valve finger is moving. This part is not available from Case. I broke the one on my 700 and I was able to weld it back together again and dress it down and it works fine. This happened 15 years ago... Gene
Brent Behner
03-06-2004 16:33:20
We Presume It Is A 400B Tractor. If So Hyd. Control Valve Is Under Gas Tank On Right Side. Have Some One Move Lever & You Look At Bell Crank & Valve Spool, Spool Should Move. Sprial Roll Pins Are Used At Two Places In That Area. If Shaft Is Broken Drill Hole In ARM & Install New Shaft & Drill Through Arm & Shaft & Install Roll Pin. Other End Of Shaft Hole For Roll Pin Must Be At Correct Angle. I Can Get Used Lever & Bell Crank. Brent
