STUPID QUESTIONS???
JSTPA
03-05-2004 20:51:13
I recenlty found the last tractor my great grandfather bought, it was an early 50's SC. I haven't got to talk to the guy that has it personally yet, but I had a few questions for you guys.First would this tractor have hydraulics? Second what is an eagle hitch? and third are parts still easily available for them?
I talked to a guy that used to work for him and knew where the tractor went, He called the guy and he is interested in selling it. But it is probably going to need some work, no big deal, but I wanted to ask these questions to you guys, so I can get an idea what I may be getting into.
Thanks , jstpa
Brent
03-06-2004 18:30:51
 Re: STUPID QUESTIONS??? in reply to JSTPA, 03-05-2004 20:51:13
We have had our SC for almost 5 years now. We absolutely love it. We have many found uses for it.
Parts aren't too bad, I guess. We haven't had to do anything to the engine besides work on the head, but I've checked into the lower engine kits as well, and they are available.
Ours is a '49, so it's got the mechanical lift. We adapted it to a cat I 3-pt, which was kinda cool. I do wish it had live hydraulics, though.
Has anyone ever messed with putting a hydraulic pump driven off the front of the engine, to give live hydraulics?
HOOSIER
03-08-2004 18:38:28
 Re: Re: STUPID QUESTIONS??? in reply to Brent, 03-06-2004 18:30:51
We put live hydrolic on a SC by installing a pump between the mag and the engine. The pump came off a case combime that had a DC engine.
Paul Janke
03-07-2004 06:59:40
I put a pump on the front of the engine on my 1941. I use it for processing firewood, so wanted one fast enough and with enough pressure to split as fast as we sawed with the buzz saw. I am running about 17-18 GPM at 2400 PSI. It can lug down and kill the tractor if held against the pressure relief for more than just a few seconds, but the wood SPLITS. I need to be careful using the hydraulics for other jobs when the engine is at lower throttle settings.
ted
03-05-2004 22:14:05
If the tractor is pre-1952, (1950-51) then it has non-live hydralics and a hydralicaly operated lift that engages only when the pto is running (clutch must be engaged and pto shifed in gear). The 1952-54 models had live pto, live hydralics and Eagle Hitch (as an option, but normal on most models). So, the question is, What year is the SC?? If it was built from 1949 on then it does have hydralics but they may not be live.
