Continental engine on VC
Kirk-Tx
03-05-2004 18:50:37
I have VC with a F400A429 continental engine. Does anyone know if a F400A50 will interchange?
I have not seen the other one. The number may be a partial. Thanks in advance. Kirk
Kirk-Tx
03-06-2004 21:21:41
 Re: Continental engine on VC in reply to Kirk-Tx, 03-05-2004 18:50:37
Thanks Mike,
My VC had been setting up for several years but was complete. I hauled it home and had it running in one afternoon. It cranks and runs fine but the engine has lots of wear(smokes). Unless the rings loosen up, I'll need to do something to it. A friend offered to give me the other engine so I may try the swap.
Alberta Mike
03-06-2004 17:41:22
To my knowledge, all F400 series Continental engines are the same, except for the cylinder bores. They came in 3 sizes, 124, 140, and 162 cubic inches. The V series Case tractors had the 124 cubic inch size. Every outside dimmension and bolt hole, etc. was the same on all three (as well as rods, cranks, camshafts, etc). I am currently restoring my model V (standard wide front) and have an engine from a MH swather from the early 60's that I am going to transplant into it this summer.
