Case 530 clutch problems
Illini Case
03-05-2004 16:19:29
530 Case triple range with hand clutch. The tractor will pull its self strongly with the hand clutch being operated. The main clutch appears to be out as I have no pedal-absolutely nothing there as pedal is completely loose. How can the hand clutch operate the drive train when the main clutch is out. I know how to change the main clutch but how do you change the hand clutch?
John Saeli
03-05-2004 16:46:29
 Re: Case 530 clutch problems in reply to Illini Case, 03-05-2004 16:19:29
Hey CASE: Sounds like the foot clutch is OK, but not releasing. Sounds like the hand clutch is OK also. Something is broken or loose inside the bell housing if everything is OK on the outside. Take the inspection cover off and look in there while someone operates the foot pedal.
Illini Case
03-05-2004 19:22:48
 Re: Re: Case 530 clutch problems in reply to John Saeli, 03-05-2004 16:46:29
John, By the inspection plate do you mean the square 4-bolt plate on the side of the torque tube or the little plug on the side of the bell housing? if the clutch is not releasing (and the rod is attached) what would you suggest as a plan of action?
Thanks
M Bush
John Saeli
03-05-2004 19:57:21
 Re: Re: Re: Case 530 clutch problems in reply to Illini Case, 03-05-2004 19:22:48
Hey CASE: It's been a while, but is there a plate on the left side just behind the bell housing flange? If there is, look in there. I would think that the problem is with the fork that engages the throw-out brg.
Klyde
03-06-2004 05:18:15
 Re: Re: Re: Re: Case 530 clutch problems in reply to John Saeli, 03-05-2004 19:57:21
I think John is right. Ball joint fork prob coming appart.
Illini Case
03-06-2004 06:46:07
 Re: Re: Re: Re: Re: Case 530 clutch problems in reply to Klyde, 03-06-2004 05:18:15
Sounds like a common problem requiring a tractor split, right?
John Saeli
03-06-2004 11:33:11
 Re: Re: Re: Re: Re: Re: Case 530 clutch problems in reply to Illini Case, 03-06-2004 06:46:07
Hey CASE: No, actually a somewhat easy fix. Look in there 1st, and determine the problem & keep us posted.
Illini Case
03-07-2004 07:02:43
 Re: Re: Re: Re: Re: Re: Re: Case 530 clutch proble in reply to John Saeli, 03-06-2004 11:33:11
John & Klyde
You won't believe this but upon examination I found a cobbled repair in the clutch linkage under the floorboard. I took it apart and repaired it correctly. The clutch does work now but I can tell it is very weak and the throwout bearing does some squeeling and squeeking since it has not been operated in no telling how long. I wish there was a way to lube it. The hand clutch has a pinging rattle to it when I engage it so it to may need replaced. I have never done a hand clutch assembly. Any pointers?
