DB 1200 - Help removing PTO (Cardan) Shaft
Phil
03-05-2004 07:53:38
I am taking the engine out of my David Brown 1200 to rebuild it and I am having problems removing the PTO shaft. According to the IT Service Manual it says to remove the PTO housing and the pto shaft (cardan) should slide right out. I've removed the housing but for some reason the shaft won't budge. Is it just stuck or is there something I'm missing? Just about everything is removed from the tractor and the transmission and clutch are both visible but I don't see anything that could be holding it other than just years of being in the same place.
If it is just stuck and needs some "convincing" does anyone have any suggestions on how to get it out? Other than pulling it with my hand I don't see anyway to hit it with a rubber mallet or anything. Thanks.
Elmer
03-06-2004 04:08:37
 Re: DB 1200 - Help removing PTO (Cardan) Shaft in reply to Phil, 03-05-2004 07:53:38
I have had that problem before. It is stuck on the pilot bearing. Remove the rear collar it is held on with a bolt. Then install a chain with some sort of weight and yank on it with the weight, just like a slide hammer.
Phil
03-06-2004 06:44:05
 Re: Re: DB 1200 - Help removing PTO (Cardan) Shaft in reply to Elmer, 03-06-2004 04:08:37
Thanks. I'll try that this afternoon.
