I can't believe it
Ol Chief
03-04-2004 21:12:43
On March 2nd I posted a question on a Case-o-matic 580 B backhoe.The question was oil capacity of the converter case and where are the check points. Cant find a level plug or dipstick.So far no one has replied to this post. Is there no one on this forum with any knowledge of this machine.If I had the owners manual I wouldn't have to ask.Thanks. Ol Chief
JCMarleau
03-06-2004 20:44:03
 Re: I can't believe it in reply to Ol Chief, 03-04-2004 21:12:43
If you need one i am sure I have a used one let me know my e mail is [email protected]
JCmarleau
03-05-2004 19:46:24
Underneath the fuel tank in front of your transmission cover 1234 r there is another cover on top of the transmission about 8or 9'' inches square with on top a big kind of nut which require a big wrench maybe 1-/1/2 unscrew this and underneath there is a dipstick welded on to this big nut for the torque if i remember right the torque holds either 1 or three gallons. If any other question my e mail is [email protected]
Ol Chief
03-06-2004 19:43:30
 Re: Re: I can't believe it in reply to JCmarleau, 03-05-2004 19:46:24
Thanks so much JC.My Plug must have been replaced ,no dipstick.I will try to find a local 580B and get a measurement then fabricate and install same.Or will ask a dealer for a drawing.The dealer that I do business with is real accomidating.Just two weeks ago I ordered a part for my Case 1175.The part is no longer supplied or mfg. but they got me a drawing with all dimensions and I was able to make it. Worked out fine.I did not ask the dealer about the 580B. He is an Ag dealer. -----For Mikes'600 Thanks for your return reply Mike.I thought that you were inferring that I am up stairs over a vacant lot.On the other hand perhaps I left a wrong impression as you have pointed out.If so I apologize.Thanks to all. Ol Chief
Mike's600
03-05-2004 18:39:53
Should be a dipstick on the top right side where the torque tube bolts up to the tranmission., or pull the the plug on the side of the bell housing and look down in the hole.
If this doesn't work , sell the tractor and get something you can work on.
Ol Chief
03-05-2004 19:32:24
 Re: Re: I can't believe it in reply to Mike's600, 03-05-2004 18:39:53
For MIKE'S 600 Thanks for the sarcastic answer.There is no Dip stick and the only plug is what I guess to be the fill hole.Besides that you cannot look down the hole.even if you could how the H--- would you know what the level should be.For your info I am not a bloody idiot.Other than thatI own 11 other tractors to work on with no intention of selling this one. For all the rest of the more sane replys,thanks a lot fellows. Ol Chief
Mike's600
03-06-2004 05:13:34
 Re: Re: Re: I can't believe it in reply to Ol Chief, 03-05-2004 19:32:24
hey ,did not mean to upset you! Your post made me think you thought the rest of us were idiots for not answering your question.
There are several post telling you where the dip stick should be located. Check that location, the dip stick could have been lost ,and replaced with a pipe plug.
I'am sorry if i came off sounding like and A#@$% !!
CK
03-05-2004 18:37:26
I don't know if the B is the same as the C but on the c you check it on the right side of machine at back of engine dipstick checked with engine running in netural.
kyhayman
03-05-2004 17:16:31
I know nothing about one, never seen one and dont have a book on it, sorry.
47vao
03-05-2004 16:15:08
ask on the crawler,dozer back hoe board thats where your answer is
rory
Michael Soldan
03-05-2004 11:59:32
Hey Old Chief, I'm guessing that a 580B is a scarce breed and not a lot of them are out there, you're right about the manual if you can find one. Sometimes no one has an answer, but we're not slighting you..we just don't know...best of luck with it...Mike in Exeter Ontario
