Case SC magneto problem
Randy
03-04-2004 16:18:23
The magneto on my 1949 Case SC will put out a spark. The tractor ran perfectly but the last time I ran it was in November. During that time we had a lot of humid weather here in Georgia so I suspect it is the points that are fouled. My problem is I have never went into a Case mag before. 1. Should I remove the cap with the mag still on the tractor?
2. What do I need to watch out for when I take the cap off?
Thanks a million
Randy
Randy
03-05-2004 03:20:45
 Re: Case SC magneto problem in reply to Randy, 03-04-2004 16:18:23
Seems like I read some where that a dollar bill could be pulled through the points to clean them.
Anybody hearded that?
Randy
Brent Behner
03-04-2004 17:55:01
Randy, You Can Remove Mag Cap While Mag Is On Tractor. Rotor Button Gear Is Timed To Mag Main Shaft. Dot On Shaft Must Align WITH TWO BEVELED TEETH On Rotor Button, Beveled Teeth Are Facing Rotor & Have Red Paint On Them. Can File Points & Set At .015 TH . To Check Timing Or Remove Mag. Remove Pipe Plug On Right Side Of Clutch Housing. Turn Engine Over By Hand & Look Through Hole Untill You See 3/16 Hole In Flywheel, Losen Mag& Push Top Of MAG To Engine. Then Remove Mag.
RandyD
03-04-2004 20:01:37
 Re: Re: Case SC magneto problem in reply to Brent Behner, 03-04-2004 17:55:01
Thanks Brent, that was exactly the answer I needed.
Randy
Mike Schotte
03-04-2004 18:45:38
Brent,
I had a question about your instructions, and was hoping you could educate me please:
When you have centered the timing mark in the inspection hole, why do you say that you need to rotate the magneto flange towards the tractor to remove it?
Regards, -Schotte
Brent Behner
03-05-2004 16:42:21
 Re: Re: Re: Case SC magneto problem in reply to Mike Schotte, 03-04-2004 18:45:38
Schotte Thanks Got Ahead Of Myself Should Move Top Of Mag To Engine 1 ST Turn Engine Until You See Hole IN fLYWHEEL. So Mag Will"t Impulse, HardTo Get Drive Lugs To Align Up. After Instalation Turn Top Of Mag Outword Until You Hear It Impluse. Timing Will Be Correct. Sorry If I Incovence You. Brent
h. parker
03-05-2004 09:15:37
a one dollar bill will work to clean the points but one hundred dollar bill works better.
robert
03-06-2004 04:48:41
 Re: Re: Re: Re: Case SC magneto problem in reply to h. parker, 03-05-2004 09:15:37
I recommend using a Canadian 20 dollar bill ,at the top of the queens head is a crown and there is diamond dust in that area that is very good for this purpose.
Brent Behner
03-05-2004 17:14:02
H PARKER Sorry Only Clean White Paper Between Points. This Comes From Point Manufactors. Color Paper Has Ink Rub Off, Points Will Arc Then Have Protusion At Point Face. Brent
