David Brown 770 Hydraulic Steering Question
Stan
03-04-2004 15:57:45
My steering cylinder got a small hole in the side and was leaking fluid. The front wheel rubbed it when turning hard left. I took it to a repair shop and they welded a patch on it. I brought it straight home and put it back on just the way I took it off. Now it doesn't want to steer. It acts like it doesn't have any fluid. The pump gets hot and so does the cylinder. Is it possible when they took it apart, they got it back together wrong. HELP!!!!! !
Elmer
03-04-2004 16:44:41
 Re: David Brown 770 Hydraulic Steering Question in reply to Stan, 03-04-2004 15:57:45
I think welding the barrel is just the beginning of your problems! The control valve is in there.
Stan
03-04-2004 17:23:59
 Re: Re: David Brown 770 Hydraulic Steering Questio in reply to Elmer, 03-04-2004 16:44:41
The patch wasn't near the control valve. Do you know how to get in there to check out the control valve.
Elmer
03-05-2004 04:31:42
 Re: Re: Re: David Brown 770 Hydraulic Steering Que in reply to Stan, 03-04-2004 17:23:59
You need special tooling to dismantle and assemble the cylinder.
