Same engine in D series tractors
Jerry Hansen
03-04-2004 14:25:49
I recently E Mailed a person on this forum,they have never heard from me in the past I,m assuming they did not return the info requested thinking it maybe spam or a possible virus.
I have a 1951 DI with water leaking into the oil, I understand it has wet sleeves hopefully it is the head gasket. I located a set of valve grind gaskets, the listing included D,DC,DO,DV not DI The person owning them advised he will not refund if not correct gaskets
Do all the D series have the same engine including my DI?
Chris
03-05-2004 11:53:18
 Re: Same engine in D series tractors in reply to Jerry Hansen, 03-04-2004 14:25:49
Something elso to look for is take a small mirror and look at the bottom of each liner where it seats at the bottom of the block. There could be pieces of the block broken off allowing water to get past the o-rings. Fixable if done right...
caseman-d
03-04-2004 19:45:32
You may want to pull the inspection plates off the oil pan and look and see if you can see where it's coming from. There should be 2 on each side. I had that problem on a D and found out the sleeves had rusted out. I pulled the plates off and it didn't take me long to find the problem. Might save you from buying a head gasket.
caseman-d
Tom Railsback
03-04-2004 15:52:42
The answer to your question is yes; all D series
tractords had the same engine.
I'm not sure I would deal with a person who is that chintzy, especially when you can buy the
same gasket set elsewhere.
E-mail me directly for particulars.
Glenn F.
03-04-2004 20:05:29
 Re: Re: Same engine in D series tractors in reply to Tom Railsback, 03-04-2004 15:52:42
I can't get the original post to pull up by itself so I'll add my comment under your's Tom...The O-rings on the sleeves could be leaking too. We've never had ours leak but they certainly could. Glenn F.
