Case DC and SC bevel gears
RedandGreen
03-03-2004 16:13:35
Anyone ever have problems with the the bevel gears in the transmission wearing out or grinding up, The reason I ask is that I have seen alot of bevel gears go out in john deere fan drives and pto's and the ring and pinion gears go out in IH tractors, Seems like bevel type gears seem to have a weeker point compard to inline gearing. Whats your thoghts?
Dave
03-05-2004 08:58:30
 Re: Case DC and SC bevel gears in reply to RedandGreen, 03-03-2004 16:13:35
Redandgreen,
As long as the bevel gears are set correctly, backlash, and contact area, and proper lube. I have seen bevel gear sets with 500hp, 1200rpm input speeds, stand up to continuous running under very heavy loads.
Just keep them lubed.
Dave
dctom
03-03-2004 16:24:20
very little problem with them they turn engine speed as all reduction is behind them and they are running in constant heavy oil,
