Light bracket on 1950 VAC
Ron in mid MO
03-03-2004 15:58:42
When I got my tractor it didn't have the side panels or lights. I have bought the side panels(off a 1947) and the strap that holds them apart is narrower than the hole spacing I got from the diagram that F-I-T had given to Chicken. I'm about 3/4" narrower. Is this going to be a problem lining up the hood?? The old strap spacing is 12 5/16", 1/4x3/8 oblong center to center.
Joe (Wa)
03-03-2004 16:53:43
 Re: Light bracket on 1950 VAC in reply to Ron in mid MO, 03-03-2004 15:58:42
Ron, parts book shows bracket p/n vt5180 for Va series before serial nr. 5570000 and bracket p/n vt5242 after. I can't tell what the difference from the parts book and it may have nothing to do with your problem. If I remember right, Frank's Vac is a '51. Joe
F-I-T
03-04-2004 16:21:10
 Re: Re: Light bracket on 1950 VAC in reply to Joe (Wa), 03-03-2004 16:53:43
Guys:
Remember that I made the bracket, then adjusted the hole locations to "fit" my hood. Joe's correct, mine is a '50, so it should be the same as the bracket you have.
Now as to the 12 5/16" span, mine wanted to be 13" to spread out enough to fit the hood sides best. If your bracket is showing 12 5/16" and that is at the center, and it shows an additional 3/16" from center on each side for outward adjustment, then on mine it could need to spread out another 5/16" off from where I customed mine to.
Not all that bad, but I'd probably wait to drill the last hole until I had the side shields in place.
Frank
Joe (Wa)
03-03-2004 17:34:22
Well, I am wrong on Frank's tractor, his web site lists it as 1950. Joe
