Here's a tough one.... Case SC
tractor tom
03-03-2004 15:24:35
Case model SC (1948). Tractor was turning over in June neighbor took mag out and could not get it running afterwards. I got involved in Sept. Put the mag back in (in time) and found that the engine was locked up. Farmer came out and said starter sometimes locked it up. Took starter out, no help. Farmer said get it out of here. So I took it. Pulled it, got it loose and running and probably ran it for a total of 2-3 hours. It has since locked up on me three times. Typically while I am turning it over trying to get it started. The last time it locked up while I was turning it over and I left it as is and tore into it. Loosened #1,2,and4 piston connecting rods. Still tight. Loosened one bolt on #3 but could not get at the other one. Still tight. Loosened #1 main, and then #2 main. Still tight. Loosened rear main and engine was loose. Took #3 piston out. All the cylinders look good, no broken rings.I looked at the bearings one at a time and they look fine. But I did see the following. The ring gear on the flywheel is really chewed up in two places 180 degrees apart from one another. The only other thing I found was 3 pieces of a small spring about the size of a clutch flex plate spring in the oil pan. Why is this thing locking up?
Michael Soldan
03-05-2004 12:09:57
 Re: Here's a tough one.... Case SC in reply to tractor tom, 03-03-2004 15:24:35
Tractor Tom, I heard about a guy who parked his tractor by his shop and removed the loader and loader frame. When he went to start it it was locked up and he couldn't turn it over with starter or by towing. He called my friend who was the local tractor mechanic to all models, who went out to his farm. After questioning the farmer about what he had recently done it was discovered quickly that when the loader frame was removed he had decided to put the studs back into the tractor and tighten them in so he wouldn't lose them..tightened one into the flywheel locking up the tractor..with the studs removed the tractor started on it own ...any chance of that? good luck from Mike in Exeter Ontario
C. Amick
03-04-2004 09:41:54
Have you pulled the front timing cover off? Could be something stuck in between the front gears.
