SC Adj. Wide Front Question
Glenn FtzGerald
03-02-2004 21:50:22
Is the main casting on a SC front end the same on a narrow front as an adjustable wide front? I'm talking about the one that bolts up to the front of the engine.
dctom
03-03-2004 17:04:37
 Re: SC Adj. Wide Front Question in reply to Glenn FtzGerald, 03-02-2004 21:50:22
NO THEY ARE NOT THE SAME ALL THREE WERE DIFFERENT SINGLE WHEEL DUAL WHEEL AND ADJUSTABLE AXLE
C. Amick
03-04-2004 11:20:49
 Re: Re: SC Adj. Wide Front Question in reply to dctom, 03-03-2004 17:04:37
I've heard that the DC fronts are all different, but I'm pretty sure a wide front axle on an SC will bolt up to another SC tractor with the dual narrow front. I'm pretty sure the single front wheel setup on the SC will not interchange with the others.
C. Amick
03-03-2004 14:30:01
They should be the same. Look up under the belly and see if the 3 bolt holes are there for mounting the bracket that holds the stablizer arms for the wide front.
ted
03-04-2004 05:12:13
 Re: Re: SC Adj. Wide Front Question in reply to C. Amick, 03-03-2004 14:30:01
DCtom is right, according to the parts book. It looks like the single front wheel gooseneck appears the same except for the weight bearing bottom section, but the numbers are different. The big difference in the two wheel narrow and the adjustable wf is the top. It is flat on the regular 2 wheel narrow front and has a round dome on the other two. From what I can see I would think you maight be able to adapt the single front if you have the adjustable front end king pin portion in tact from the widefront. Clear as mud??
