Case SC differential shaft oilseals
Frank
03-02-2004 20:04:40
Trans oil leaking at brakes on 1949 Case SC.Need new seals on differential shafts. Case part # 03866AB. What is the cross # to National or other seal manufactures. Want to have new seals before I start. Frank
Dave
03-03-2004 06:30:58
 Re: Case SC differential shaft oilseals in reply to Frank, 03-02-2004 20:04:40
Frank,
The National number is 415458.
I did the brakes on mine, just be careful when you put the seal cage and bearing carrier back in, because that differential shaft will sag when you take the cover off, and the spline may cut the seal.
Just do one side at a time, keep the shims together.
Dave
Klyde
03-03-2004 10:43:21
 Re: Re: Case SC differential shaft oilseals in reply to Dave, 03-03-2004 06:30:58
To keep it from "saging" do one side at a time and tighten or lock he brake on he other side.
Mike Schotte
03-03-2004 04:44:12
n/t
