axle seal part number for 48 vac?
mike
03-02-2004 12:35:51
Can anyone tell me the part number for the outer axle seal for a '48 VAC? The local case dealer isn't too bright when it comes to older cases. Thanks in advance
Mike
Mike
03-04-2004 08:50:46
 Re: axle seal part number for 48 vac? in reply to mike, 03-02-2004 12:35:51
Ok, I tried several case dealers and they came up with a number of A30526 in lieu of A30529. But what I do need to know if that is both inner and outer seals same number of if this is just the inner or outter felt? Can anyone tell me. HEY F-I-T. you would know.. you replaced your didn't you?
thanks again for all your help.
Chicken
03-02-2004 14:57:59
I just went through this with my dealer try these numbers
J I Case Seal # VT 3749
CR Seal # 25745
Hope these help
Pete
Joe (Wa)
03-02-2004 22:24:33
 Re: Re: axle seal part number for 48 vac? in reply to Chicken, 03-02-2004 14:57:59
Part # VT3749 may have been changed to A30529. Dealer should be able to cross the later number back to the VT #. Joe
mike
03-02-2004 15:03:55
Thanks, I'll give them a try
Mike
