caseomatic 3-point hydraulics
roger d. moore
03-01-2004 05:48:31
hey, all you case mechanics, help, what can possibly be wrong with a 400 series tractor that pumps all of the oil from the torque tube to the transmission while raising the 3-point hitch, no oil going back to torque tube. got to be something simple but it has my mechanic baffled.
Roger (Mi)
03-01-2004 14:11:14
 Re: caseomatic 3-point hydraulics in reply to roger d. moore, 03-01-2004 05:48:31
Klyde is correct! The seals in hydraulic lift piston in the rock shaft are worn out. Remove the rock shaft/cover and replace the piston seals. Yes, there is a seal between the torque tube and transmission, but it's above the oil levels. It could be totally worn out and not leak enough to be considered serious.
Klyde
03-01-2004 10:33:22
If it transfers oil just when raising the hitch, then the seal on the piston for the hitch is shot, or the cylinder in he top cover is cracked.
dbeiter
03-01-2004 09:00:23
You have a seal between the tranny and torque tube blown out, I have replaced this seal in all of my small Rock Island series tractors (530, 600, 311 etc)
