Backhoe tire
Kent in KC
10-03-2006 07:20:08
Good morning,
I am in the Kansas City area (Smithville) and need a tire for my Case 580K, specifically a Contractor F-3, four groove, sawtooth rib 11L-16SL tube type. Used is fine, mounted is too. Can anyone point me in the right direction? Thanks.
Kent Hartland
Joseph A Francano III
10-03-2006 08:23:47
 Re: Backhoe tire in reply to Kent in KC, 10-03-2006 07:20:08
I converted mine to 235/85/r16's. Height was the same and they are way easier to get. You would need to do the pair of course. Since you are using your backhoe off road and at slow speeds, you can just put a tube in a tubeless tire with no ill effects.
Good luck.
JGarner
10-03-2006 12:15:03
 Re: Backhoe tire in reply to Joseph A Francano III, 10-03-2006 08:23:47
As an FYI, they make tubes for Radial tires. They are more costly but can be used at highway speeds in your tubeless radials. I have done this anytime I have had a radial with good tread left that has a sidewall puncture. These punctures are next impossible to fix since the radial sidewalls flex.
10-04-2006 22:01:28
 Re: Backhoe tire in reply to JGarner, 10-03-2006 12:15:03
Not to rain on your parade, but these tubes are not legal to use. If a tire branded tubeless with a tube in it fails at highway speed any court will find that the failure was due to misapplication and thus negligence. I have fixed thousands of tires, I know these tubes work (as will regular tube type tubes-radial or bias with tube powder) but they are not designed to be used this way. The liability of doing this is not worth losing your house and valuebles.
