DB 990 CLUTCH
James Clough
07-06-1999 09:27:27
I have a DB 990 with Loader that has now had two clutches (complete ) in less than 250 Hrs use . When the first one needed reeplacing which was fitted by a Tractor Dealers I decided to do the replacement myself . The cost of the parts are bad enough without paying someone to fit it (alot of thebill being to remove the loader .
I fitted the clutch with new plates , cover and thrust plate and all went together very well . The problem that I have now is that I have already in less than 35hrs use had to adjust the clutch 5-6 times and only have 1/2 inch adjustment left on the rod .
I have spoken to the clutch supplier and all they have suggested that the flywheel needs skiming and so the tractor will need to be split again . Is this the right answer ?.
Any help would be appreciated .
Elmer
07-07-1999 10:02:07
 Re: DB 990 CLUTCH in reply to James Clough, 07-06-1999 09:27:27
Remember the flywheel surface is for the PTO, and the separetor plate is for the traction. If the separetor plate is scored and you don't want to spend the money resurfacing it, and don't put many hours on the PTO you can turn it around. But with the banning of asbestos the new material on some discs do not last up.
Woodbeef
07-06-1999 18:15:32
If the dealer did not resurface the flywheel,then that is probably your answer,as to why your tractor has such an appetite for clutch discs.
Elmer
07-06-1999 16:01:57
Whose clutch are you using. I have had discs from a certain company wear out in 200 hrs. Email me, I don't like to condemn anybodys product.
