Stick in filter? Remove or leave?
Joe Fabregas
07-05-1999 15:33:58
New CASE filter for my VAC has a stick in the middle of it. I seem to remember the stick holds the filter media at bay until it is installed and pressurized. When I removed the old filter the stick was still in place. Does the stick stay or get removed at installation? Thanks. Joe Fabregas [email protected]
TMAC
07-06-1999 18:51:37
 Re: Stick in filter? Remove or leave? in reply to Joe Fabregas, 07-05-1999 15:33:58
That stick is to be removed before installing. Your filter base on the engine is supposed to have a metal stem that I beleive oil goes up and out into the filter. Your stem may be missing.
Jeff King
07-07-1999 20:04:47
 Re: Re: Stick in filter? Remove or leave? in reply to TMAC, 07-06-1999 18:51:37
TMAC is correct. Take out the stick, there is supposed to be a 3/16 pipe stem going up to the top of the filter that the oil percolates out of. If yours is missing, oil is not getting filtered. These engines are a bypass type filter system anyway, where only a portion of the oil gets filtered. Found the same thing on my '300 148 CID. Had probably been missing for a dozen years, and boy were the bearings bad from it. Made a replacement stem out of piece of old brake line.
jpk
