870 power steering
jb
02-29-2004 07:42:57
The power steering is weak on my 870. When it idles, not moving, it is almost impossible to turn the stering wheel. What should I check?
Shane
03-01-2004 05:02:55
 Re: 870 power steering in reply to jb, 02-29-2004 07:42:57
It could be your hydraulic pump too, if it turns easily when throttled up I would think that the pump is weak.
Dale
02-29-2004 16:01:55
Jack the front end up and try to steer it, we have seen these spindles try to seize, even under normal use, with only 1 grease fitting some parts of the spindle gets terribly dry. Dale
