59 Case 400 Case-O-Matic Question
Don L
02-28-2004 19:10:59
Have 59 400 case-o-matic. Not sure if I have the correct dipstick for the case-o-matic / dual range
oil level. Does someone out there know how far down on the stick the oil level should be? The dipstick this tractor has looks the same as the engine oil dipstick. Also would like to purchase
the covers for the batery and the fuel tank-oil fill.
Thank you for your help in this matter.
Don L
BobV
03-01-2004 17:06:48
 Re: 59 Case 400 Case-O-Matic Question in reply to Don L, 02-28-2004 19:10:59
DonL: I looked up the P/N's for the dip stick engine G37037,and the torque tube G45150 the appearances are different the engine has a small cup on the stick, while the torque tube has a flat cap length hard to say from drawing if both are the same lengh. Are you fixing up for self or going to sell? Good luck hope this can help some.
Don L
03-02-2004 19:39:06
 Re: Re: 59 Case 400 Case-O-Matic Question in reply to BobV, 03-01-2004 17:06:48
Bob V
I just bought this tractor by sealed bid. I am going to restore it for my own collection. I'll need to overhaul the engine and fix a few things, but the tractor is straight with less than 2000 original hours on it. I need to find the covers for the hood to make it complete. Thank you for your information on the oil dipsticks.
Don L
Roger H.
02-29-2004 13:43:54
Don; It's possible you do have the wrong dipstick
I purchased a new 630 and was having trouble with it working right, especially on hillsides, and after a lot of complaining the dealer came out and sawed part of it off and then it was better. never was avery good system on that tractor though. Not sure if the two were basically the same or not. Roger
