Case VAC compression
Steve Lehman
02-28-2004 16:11:30
What is the compression supposed to be on a Case VAC? I just checked mine at 110 - 115 - 115 - 110. If I were to guess, I'd say that that it pretty good.
Tractorboy
02-28-2004 17:26:26
 Re: Case VAC compression in reply to Steve Lehman, 02-28-2004 16:11:30
95 - 105 lbs all cylinders within 5 lbs. Yep you're good. You may have some carbon build-up. Go give it a work out and check again.
