hydraulics Case 990 David Brown
Tony
02-27-2004 14:33:31
What kind of hyd.fluid & where do you change it.
Elmer
02-28-2004 08:52:48
 Re: hydraulics Case 990 David Brown in reply to Tony, 02-27-2004 14:33:31
Any kind of tractor transmission hydraulic fluid will do. Look under the transmission directly below the transmission shifters. You will see a sump cover about 4 inches in depth. There is a drain plug on the side of it. Drain it and remove the cover. Be sure to see that the bypass screen goes into the new filter. There is also another drain plug about a foot back from the sump which will get another 5 or 6 litres. An 1 1/8 wrench fits it.
