Hyd pto houseing bolts on 930. what do I tourque t
R Wyler
02-27-2004 08:00:45
I am getting ready to remove the hyd/pto houseing on my 930 and my book simply does not sayu what to tourque the cap scews attaching it to the trans case. I want to get it right. Also what about the pto shaft and hyd pump attachuing cap screws? Thanks for the help. e-mail me if you like. R Wyler
Jim Handke
02-27-2004 19:14:51
 Re: Hyd pto houseing bolts on 930. what do I tourq in reply to R Wyler, 02-27-2004 08:00:45
We put a 3 foot cheater pipe on our 3/4 inch ratchet and torque them fairly tight.
R Wyler
02-27-2004 19:43:03
 Re: Re: Hyd pto houseing bolts on 930. what do I t in reply to Jim Handke, 02-27-2004 19:14:51
THanks for the tip Jim. I think 50 ft pounds is pretty tight so I think that is what I will do. R Wyler
DKase
02-27-2004 20:52:27
 Re: Re: Re: Hyd pto houseing bolts on 930. what do in reply to R Wyler, 02-27-2004 19:43:03
I think you had better do quite a bit better than 50 ft. pounds! They are 5/8" bolts and you should be closer to 200 ft.#. 50# can be achieved by one hand on a 8" wrench. Most good service manuals have a section that will show torque specs. by the size, thread, and and bolt grade.
R Wyler
02-28-2004 06:36:26
 Re: Re: Re: Re: Hyd pto houseing bolts on 930. wha in reply to DKase, 02-27-2004 20:52:27
THanks D Kase my book does have a chart I'll check it out.
Roger
02-27-2004 08:03:01
I don't think there is any torque spec's just as long as they are tight.
R Wyler
02-27-2004 08:05:43
 Re: Re: Hyd pto houseing bolts on 930. what do I t in reply to Roger, 02-27-2004 08:03:01
Thanks Roger I know the outside bearing carriers look like they use the same size bolts and it says 50ft pounds for them. I will just look at it and use common sense if there is no factory specific torque for them. R Wyler
