Case 430 - PTO and Hydro Questions
Rob -TX
02-27-2004 07:48:09
Two Questions -
1. When the tractor is cold - pto will turn fairly strongly without being engaged - couple of minutes then stops and works fine from then on.
2. when pulling my 6' bruush hog on level ground - the shredder will slowly drop until the runners are on the ground - sometimes it will correct itself and jump back up. Other than that it will lift just fine.
Any Ideas
JCMarleau
02-27-2004 20:18:47
 Re: Case 430 - PTO and Hydro Questions in reply to Rob -TX, 02-27-2004 07:48:09
Sad enough you will have to live with this problem as it is very normal for 430 and 530 when you live in the north part of america. I sold 200 of those tractor and every one of them had the same problem in the winter where you could never get the p.to. to stop and be very cautious in handling this when you hook it to an equipment as one of my customer tried to stop it one morning like every other morning but for some reason his mitts caught up in the shaft and he lost his thumb. He sued Case co. and the only thing they said was that we were the only dealership in north america to complain about this problem but when this customer sued them they send three engineer for two weeks to try and solve the problem but to no avail. they block the 80-90 oil from the differential which is thick oil and they install a frost plug and put lighter oil like hy trans plus but only slightly help the problem when not too cold.
