Okay, here's a picture of the
Les...fortunate
02-26-2004 12:15:45
third party image
magneto and the spark plug wires on the SC. Tell me, is this the way it's supposed to be or is it off 180o?
Dr Cy Kosis
02-26-2004 19:15:51
 Re: Okay, here's a picture of the in reply to Les...fortunate, 02-26-2004 12:15:45
Dang Les....
Looks like you must be building yourself quite a puller.
Ain't that one of them there aftermarket high performance Al-lum-minim racin' heads on there?
You might shoulda kept that one top secret now everyone else will want one too.
Les...Naw
02-27-2004 02:24:31
 Re: Re: Okay, here's a picture of the in reply to Dr Cy Kosis, 02-26-2004 19:15:51
That's what the head looked like when it came back from the shop. Somethin on the ole boy has to have paint onnit and there's about $500 worth.
Me building a puller???? Believe me, there ain't NO chance of that.
Sure you did...
02-27-2004 03:49:22
 Re: Re: Re: Okay, here's a picture of the in reply to Les...Naw, 02-27-2004 02:24:31
Les-
Who says that old SC ain't a pulling tractor?
I bet it pulled that wallet RIGHT out of your pants! (grin)
-Schotte
(p.s. - tell Sky to say "hey" on the boards more often. I like hearing what he's working on and seeing photos of the project.)
Les
02-27-2004 04:08:40
 Re: Re: Re: Re: Okay, here's a picture of the in reply to Sure you did..., 02-27-2004 03:49:22
You got that right about the pullin, Mike. I got a feelin it ain't done yet.
Mike Schotte
02-26-2004 14:28:01
Les,
If I'm reading those two overlapping wires right- instead of 1-3-4-2, you've got it hooked up 4-2-1-3.
The front of the tractor is cylinder #1, the upper right distributor nipple is #1, and it rotates clockwise (as you face it.)
As your picture shows:
1 is hooked to #4 cylinder
3 is hooked to #2
4 is hooked to #1
2 is hooked to #3
YEP- 180 degrees off.
-Schotte
Les...Ayup
02-26-2004 15:55:37
 Re: Re: Okay, here's a picture of the in reply to Mike Schotte, 02-26-2004 14:28:01
That is exactly correct. And thank you both for your responses.
Les...Oops
02-26-2004 16:01:28
 Re: Re: Re: Okay, here's a picture of the in reply to Les...Ayup, 02-26-2004 15:55:37
I spoke too soon, Mike. It goes like this:
Magneto - Plug #1 #4 #2 #2 #3 #1 #4 #3
Mike Schotte
02-26-2004 16:52:30
 Re: Re: Re: Re: Okay, here's a picture of the in reply to Les...Oops, 02-26-2004 16:01:28
I think you're still confusing something, Les.
Upper right on distributer cap is #1
Lower right is #3
Lower left is #4
Upper left is #2
It rotates clockwise.
Some magneto caps only label #1 nipple, but others list the 1-3-4-2.
third party image
It makes sense if you look at it as firing order, it makes no sense if you think it should be 1-2-3-4 ! (grin)
-Schotte
Les...Yer right
02-26-2004 17:17:19
 Re: Re: Re: Re: Re: Okay, here's a picture of the in reply to Mike Schotte, 02-26-2004 16:52:30
Numberin them things like that don't make no sense at all.
dctom
02-26-2004 12:45:34
it is off 180 but dont hurt anything, if you want it right just take mag off and rotate 180 and put back on and move wires 180
Klyde
02-26-2004 21:29:22
 Re: Re: Okay, here's a picture of the in reply to dctom, 02-26-2004 12:45:34
If your rotating the impulse coupler, you better go 360 degrees or you're gona be 3/4 of a turn off. THEY WILL GO ON 4 DIFFERENT WAYS.
Right again...
02-27-2004 02:37:52
 Re: Re: Re: Okay, here's a picture of the in reply to Klyde, 02-26-2004 21:29:22
Yep- 180 degree of a turn on the back end of the magneto will get you a 1/4 turn (90 degrees) on the rotor end.
The IH mags have a dot on the impulse coupling- so if you know which cylinder your rotor was pointed to when you pulled the mag, and you know whether the impulse dot was facing towards or away from the engine block... you can put it back on like it was without having to spin the engine to #1 TDC.
-Schotte
