weight of 580ck 'b' with backhoe attachment
joseph a franca
02-25-2004 14:25:29
Hello,
Trying to find out the weight of a 580ck 'b' 1972 with the backhoe attachment.
My friend wont let me put it on his flatbed if it is over 10,000lbs.
Thanks
mike
02-26-2004 00:02:08
 Re: weight of 580ck 'b' with backhoe attachment in reply to joseph a francano iii, 02-25-2004 14:25:29
A 530 ck which is the older version of a 580 according to the book is 8800#s all together I'd say take off the loader bucket and maybe hoe bucket and should be under 10000 pretty easy hope this helps good luck mike
hmmmm
02-25-2004 21:23:05
why not put it on a scales????
02-25-2004 22:26:06
 Re: Re: weight of 580ck 'b' with backhoe attachmen in reply to hmmmm, 02-25-2004 21:23:05
it is a little tough to get a scale in the woods to weigh a tractor that has vines grown all over it.
Joel
02-25-2004 16:42:35
Joseph,
These weights are from the manual for my 1983 580D:
Operating weight for standard machine 11758 lbs
Add for 4-In-1 bucket 1130 lbs
Add for Extendahoe & front counterweight 1255 lbs
Add for cab with air conditioning 660 lbs
Add for cab without air conditioning 630 lbs
*4 wheel drive machines weights below
Standard machine 12453 lbs
Extendahoe machine 13604 lbs
Hope this helps.
02-25-2004 17:33:22
 Re: Re: weight of 580ck 'b' with backhoe attachmen in reply to Joel, 02-25-2004 16:42:35
Looks like I am stripping this one in the field.
