1070 case
reds
02-25-2004 07:17:56
start it up and put it in gear, but it dont move.any suggestions or might be"s
gip
02-26-2004 19:34:44
 Re: 1070 case in reply to reds, 02-25-2004 07:17:56
frt. imput gear on counter shaft may have came off,seen it some over the years.
Don
02-25-2004 18:30:19
If it's a powershift, the torque-limiter clutch may have sheared the rivets between the disc and the hub. Or you may have no oil pressure, but you wouldn't have hydraulics either. If it's a standard, the clutch also may have sheared the disc from the hub, or its not going into gear.
turbo
02-25-2004 18:25:16
Does your power steering and 3pt work?
