98 dodge ram has me stumped?
chris
02-24-2004 20:10:56
i have a 1998 dodge 1500 pickup, the problem is all my gauges stopped working? (fuel,oil presure, temp,alt, speddomiter,etc) i have checked all the fuses but all look ok? is their a relay that i am overlooking? I know i am not on the right discussion board, but anyone smart enough to be involved with case equipment can surely help me out with this (i hope) small problem. thanks a million
EARL'S GARAGE
10-03-2006 19:29:51
 Re: 98 dodge ram has me stumped? in reply to chris, 02-24-2004 20:10:56
FILL YOUR FUEL TANK COMPLETELY FULL. I BET EVERYTHING WILL WORK AGAIN. EARL
Chris Vangel
02-26-2004 09:34:31
I worked for a Chrysler dealer for nearly three years as a technician. If all the gauges stopped simultaneously, you most likely have a printed circuit board that has failed. It mounts to the back of the gauge cluster. Don't bother looking for an IVR (instrument voltage regulator), it doesn't have one. If fuses are good, remove the cluster and examine the board, often times you can see a burnt spot on the board. Yes, the cluster should go through the PCM or the BCM, Powertrain Control Module or Body Control Module. Odds are against either module being the cause, but it is possible. Does the odometer still read? If that is dead also it would still make me look at the circuit board as the primary fault. I hope this helps. It's just not easy anymore is it? Chris.
Mike's600
02-25-2004 16:28:48
Check with Dodge for any re-calls on the guage set.Your guage set is most likely computerized, not going to be a simple cheap fix.Just my experience with Dodge .
G. L. Grumpy
02-25-2004 07:14:10
Had an S-10 once that had a small fuse to gauges, and wouldn't charge either. The gauge fuse also kept the charge circuit on somehow. SO, recheck those fuses, pull out to look at them. GM also has two or so boxes under hoods anymore, have you checked for any of those? Harness plug ins? Squeeze all of them while someone watches the gauges.
hank
02-25-2004 05:16:56
check for a broken ground
Klyde
02-24-2004 22:09:57
Don't know if they still have it but there used to be a voltage regulator that pluged into the back of the dash that controled all the power to gauges. Had one fall out once plowin snow, guess i hit the bank too hard.
caseman-d
02-24-2004 20:42:43
I suppose calling your local Chevy dealer is out of the question????? All in fun
caseman-d
DKase
02-24-2004 20:24:41
Do your dash lights work? If not you might want to check the plug in where the wiring harness connects to the back of the dash. LOL
Tim Pennell
02-24-2004 20:14:57
check your fuseable links, think there are some under the hood..... ....
Allan C
02-25-2004 21:02:40
 Re: Re: 98 dodge ram has me stumped? in reply to Tim Pennell, 02-24-2004 20:14:57
Check grounds! I've seen Chevys with crazy guages and it was the Battery ground to the fender not making contact. If it's a diesel there aren't many other clues.
