I need info on Dupont and or other brands for Powe
R Wyler
02-24-2004 16:51:34
I am needing a little Power Red for my 930 and Case plows I need the 50s 60s era shade of Power Red. I give up on those elsegundo cheap brands that are JUNK. I want to buy some auto paint like I hear many restorers use. Where do I find a good Dupont or Tisco paint dealer in north central OK? Also what is the Dupont paint code # for Power Red? I think I know of a Dupont dealer nearby. Thanks for any help. R Wyler
MGM
02-27-2004 03:33:34
 Re: I need info on Dupont and or other brands for in reply to R Wyler, 02-24-2004 16:51:34
I bought my paint right from the Case dealer, anywhere from 38 to 50 dollars a gallon, put in on straight , no thinner beautiful job. Dupont acrylic enamel is super paint but you may pay $120 a gallon for it, Im totally satisfied with Case paint
Mike
R Wyler
03-04-2004 09:19:34
 Re: Re: I need info on Dupont and or other brands in reply to MGM, 02-27-2004 03:33:34
Yes I have used that Case paint and it is very nice. My main reason for looking into the other brands is I think I need Flambeau Red. R Wyler
Old Eb
02-26-2004 09:23:35
Power Red is not the same as Flambeau - use it if you like but it won't quite be correct. Flambeau was used even on some of the early 70 series - till 1974 I think (without looking it up). I can get you the "recipe" for Flambeau if you like - let me know.
R Wyler
02-26-2004 09:43:38
 Re: Re: I need info on Dupont and or other brands in reply to Old Eb, 02-26-2004 09:23:35
Ok I was think that Power red went into use in the later 50s or 60s. I would like to have the Dupont # for Flambeau red. Thanks for the help. R Wyler
bill
02-25-2004 17:58:53
Just take the factory can of paint being power red to your closest DUPONT paint store. they can cross the number on the can of your paint and find the power red in what you want.
R Wyler
02-25-2004 19:33:39
 Re: Re: I need info on Dupont and or other brands in reply to bill , 02-25-2004 17:58:53
Thanks for the info I didn't realize they could do that. I will find a Dupont dealer and talk to them. R Wyler
Glenn/Mn
02-24-2004 18:20:37
go to a NAPA store they have Martin Senour brand not all stores can mix an acrylic enamel call first for dupont I have a list that says G8156 for power red
R Wyler
02-24-2004 18:26:41
 Re: Re: I need info on Dupont and or other brands in reply to Glenn/Mn, 02-24-2004 18:20:37
THanks for the info I will check around. I have a Napa nearby that mixes paint I think. I might check with them. Thanks for the Code # as well. R Wyler
Glenn/Mn
02-24-2004 18:36:44
 Re: Re: Re: I need info on Dupont and or other bra in reply to R Wyler, 02-24-2004 18:26:41
Flambeau red is the correct paint for the older tractors Power red is for the newer ones
R Wyler
02-25-2004 19:31:31
 Re: Re: Re: Re: I need info on Dupont and or other in reply to Glenn/Mn, 02-24-2004 18:36:44
Yes I think power red is what the 930s use so that is what I have been useing. Thanks for the help. R Wyler
