Case SC ser#sc8032301 overhaul info
Wolverine
02-24-2004 16:33:58
My foot clutch Sc is ser# SC8032301. I am getting a lot of gas in oil. figure I need an overhaul right? If so are the parts I need available? costly?
C. Amick
02-25-2004 08:36:32
 Re: Case SC ser#sc8032301 overhaul info in reply to Wolverine, 02-24-2004 16:33:58
Sounds like your spark plugs must be fowling out. Could be caused by the oil burning. A hotter plug might help. What spark plugs are you using?
Brent Behner
02-24-2004 17:28:05
WOLVERINE 1st check compression should be 100 lbs. remove air cleaner & open throttle & CHECK CHOKE FOR OPEN. CHECK TAPPET GAP & SET AT 0.10 THEN CHECK COMPRESSION & RECORD. NEXT SQUIRT OIL INTO CYLINDERS & CHECK & RECORD PRESSURES. IF COMPRESSION IS HIGHER WITH OIL IN CYLINDERS; THEN OVERHAUL ENGINE. OVERHAUL JOBS are EXPENSIVE IF DONE WRIGHT. VALVE PETRUSION ABOVE VALVE SEATS IS IMPORTMENT. SPARK PLUGS & WIRES IS IMPORTMENT. BRENT
