Rebuild kits for Case S
novice
02-24-2004 16:26:16
Anyone know of a source for parts (sleeves, pistons, bearings, gaskets,...etc) for a rebuild of a Case S other than the Case-IH dealer??
caseman-d
02-25-2004 12:27:03
 Re: Rebuild kits for Case S in reply to novice, 02-24-2004 16:26:16
You can still get sleeves and some other parts from Case, they don't show them in kits anymore. I priced a valve grind gasket kit out for a guy just a few minutes ago for around 60.00. Not sure about the price on the slleves, will try to look again soon.
caseman-d
C. Amick
02-25-2004 13:40:39
 Re: Re: Rebuild kits for Case S in reply to caseman-d, 02-25-2004 12:27:03
If you check on sleeves with a Case dealer, see if they stock any 3-11/16" SC sleeves with the single "O" ring.
C. Amick
02-25-2004 09:21:57
There are no rebuild "kits" available. Engine bearings are available as "reconditioned" from Don L. Don L. also has piston and sleeves sets available from time to time. Piston rings and gasket sets are available from several sources.
