Couple of SC questions
Les...fortunate
02-24-2004 15:38:27
1) Does anyone know of a particular alternator that might fit without having to fabricate a whole lot of bracktes and stuff?
2) The way the plug wires are connected from the magneto doesn't make any sense according to the firing order stamped on the block. Yet the tractor runs great. Any help there?
todd hamilton
02-24-2004 19:58:25
 Re: Couple of SC questions in reply to Les...fortunate, 02-24-2004 15:38:27
third party image
I put the 10SI Delco on mine using the instructions of off this site a little over three years ago. It will bolt up at the bottom, I took a piece of flat stock with the original top bracket and made a scissor (pivots in middle) to adjust the belt tension at the top. I used some flexible stock to fasten the back of the alternator to the engine block so that it would not cavitate. The pulley sizes don't exactly match so if you don't put the original on the alternater it will groove the belt a little. My belt is "groovy" but seems to not hurt anything. Watch that you do not put too much tension on the old water pump and be sure to wire it according to instructions with the protection diode. Failure to install the diode will cause the battery to drain through the alternator when the tractor is not running.
12 volt conversion link
02-24-2004 20:07:50
 Re: Re: Couple of SC questions in reply to todd hamilton, 02-24-2004 19:58:25
Here are the instructions - worked very well for me. Todd H.
Les...fortunate
02-25-2004 16:41:35
 Re: Re: Re: Couple of SC questions in reply to 12 volt conversion link, 02-24-2004 20:07:50
Thanks for that link, Todd. I'm only interested in charging the battery and even that is not a huge concern as I'll just put it on the charger as needed.
Nobody wants to tackle the firing order question, eh?
Mike Schotte
02-25-2004 17:28:41
 Re: Re: Re: Re: Couple of SC questions in reply to Les...fortunate, 02-25-2004 16:41:35
I would have given the firing order/magneto question a go... but you didn't supply much in the way of info, Les. How do you have it hooked up?
Remember that the rotor turns clockwise 1-3-4-2 while the impulse rotates counter-clockwise (or anti-clockwise for you Brits out there...)
-Schotte
Les
02-25-2004 18:34:55
 Re: Re: Re: Re: Re: Couple of SC questions in reply to Mike Schotte, 02-25-2004 17:28:41
I'll get a picture of it if I can. I do know that the wire from the #1 position runs to the #4 plug. Maybe Sky will get on here and tell you since he still has the thing in his possession. And he's the one who hooked it up the way it is.
Bob L.
02-24-2004 16:28:25
I'm sure Mike Schotte will be glad to help you out on that alternator question!
