Case SC Kill Switch Part No. for Elliott in ILL
C. Amick
02-24-2004 14:24:22
The NAPA Part No. for the kill switch is: PP6354. It looks very close to the original switch. Again, it is a two post switch and you will have to run one post to ground if you are using a magneto.
Josh
02-25-2004 09:54:54
 Re: Case SC Kill Switch Part No. for Elliott in IL in reply to C. Amick, 02-24-2004 14:24:22
I am restoring my '41 SC. The kill switch is missing. The NAPA switch has to have one side grounded, and then the switch is pulled out to ground the mag. Is this how the tractor initially was? Pull the switch to stop? I would have thought the other way around. thanks for the help!
Josh
Elliott from IL
02-25-2004 18:50:02
 Re: Re: Case SC Kill Switch Part No. for Elliott i in reply to Josh, 02-25-2004 09:54:54
Josh that is right. It said in the Operators Manual that to start the tractor to push down on the magneto switch button. Yes you would have to ground out one side. Its on page # 8. Elliott
push in the
Elliott from ILL
02-24-2004 17:03:51
Thanks C. Amick. I just got one today at NAPA. Looked up in the notes and found it after all. Should I use one more of the same switch Echlin(PP6354) for the lights too? Thanks for the info. Elliott
Mike Schotte
02-24-2004 18:41:44
 Re: Re: Case SC Kill Switch Part No. for Elliott i in reply to Elliott from ILL, 02-24-2004 17:03:51
Hi Elliot,
I didn't respond to your earlier post because I thought you were trying to find actual N.O.S. switches.
I bought the NAPA switches, too... and they are pretty close. My DC still has the original switches on it- so someday I'll take a picture for side-by-side comparison. The originals are smaller and a little more rounded.
Here's a pic that I took the other day of the NAPA switches:
third party image
-Schotte
