1175
Pete-Tex
07-02-1999 12:37:28
On my shifter lever (4spd hi/lo) the lever slips between the gear tumblers (between R and 1/2 also between 1/2 and 3/4), have to be very carefiul shifting. What is the fix?
Also should you be able to see the hydro fluid thru the 2 knobs on the left rear of the trans case, Mine are dark. can they be unscrewed and/or replaced or cleaned?.
Wade Krivanek
08-10-1999 22:37:39
 Re: 1175 in reply to Pete-Tex, 07-02-1999 12:37:28
The glass sight knobs can be unscrewed and cleaned if you can remove them without breaking them. If they do break their easy enough to replace. But you have to be careful so that no glass ends up in your transmission case. When the fluid is low on my 1170 they usually look white in color. I wish Case would have installed a dipstick instead.
ED
07-04-1999 13:11:07
You might try replacing the pin that holds the shifter in place.
