Battery for 430 Diesel
Lee
02-24-2004 05:22:48
When I went to Tractor Supply to get a new battery for my 430 Diesel, it says that it takes 2 6-volt batteries, like a 730 / 830 diesel that my father has. I don't see how they would both fit in the hole! So I'm not sure which battery to get for this tractor. Any advice? Thanks!
Roger (Mi)
02-26-2004 21:19:13
 Re: Battery for 430 Diesel in reply to Lee, 02-24-2004 05:22:48
The reason for two six volt batteries hooked in series (which equals 12 volts) is because the steering shaft goes through the middle of the battery tray on 430's. You could put one twelve volt battery on one side as long as you don't need to start it often in cold weather.
Mark
02-24-2004 08:54:40
I had a 530, the book said the same thing. I ran a single 12v with no problem.
David J. Beiter
03-09-2004 09:04:43
 Re: Re: Battery for 430 Diesel in reply to Mark, 02-24-2004 08:54:40
You must not live in a cold climate... I have a 530 diesel and a 1000CCA 12 volt wont get it below 20 degrees
Illini Case
02-24-2004 06:40:00
My 430D has a autozone 12 volt battery of about 750cca. Any single 12 volt battery will work as long as it fits in the battery tray and that you can fasten it down.
Gaylon Schlatter
03-01-2004 17:04:12
 Re: Re: Battery for 430 Diesel in reply to Illini Case, 02-24-2004 06:40:00
I'm also running a single twelve volt battery,on my case 430 Diesel with no trouble.
