Lift arm help
Chris
02-22-2004 02:47:04
I have a Case 990 david brown
Cant get the lift arms to work at all.
The arm lock is unlocked, the hydr.pump makes good pressure, dosent matter if the pto clutch is in or out. Where do I go from here? Thanx.
Barry
02-24-2004 07:10:45
 Re: Lift arm help in reply to Chris, 02-22-2004 02:47:04
Chris, I don't know about your model, but I have an old ~1971 DB that had Lift Arm problems and I had to disassemble the whole assembly to unstick a spool valve in the control valve. Your best bet is to get in contact with Elmer. He is a DB guru and probably can help you. If you search the archives and this section, you may be able to get some more places to check. I emailed him in the middle of last year and his address was [email protected] and I guess it is still the same. Good Luck.
Barry
