lift
Geo
02-21-2004 19:28:04
I have a David Brown 990, about 1970, it will lift the impliment and let the impliment down but will not hold it in place. When the lift is in the up position the hydrolic system runs all the time as you can here it. When I first bought the tractor it would have a happy median and stay in one place. Now it is to where it has the implement either going up or down with no happy median. Any suggestions?
Thanks
Gw
Chicken
02-21-2004 22:02:07
 Re: lift in reply to Geo, 02-21-2004 19:28:04
I am not a hydraulic Tech but sounds as though you have valve trouble, once lifted the valve should close and hold the hydraulic fluid in the system. if it is lowering the implement it is leaking in the valve or a ram or piston Just a good place to start to look for trouble,
Iam sure there are more people able to give much better info than me.
Pete
