Making sense of SC/DC part numbers
Glenn FitzGeral
02-21-2004 18:10:02
I'm still chasing this front wheel weight issue. Wheel weight #5364A apparently is used on SC and DC front wheels. DC wheel #5818A and SC wheels #04556AB and #04055TS, I'm told. Can anyone tell me what wheels these are? Are they stamped wheels? Why two for the SC? I was reading in the archives tonight and discovered the SC could have a 16" cast iron front wheel similar to the DC but narrower. Are the cast iron wheels on a 54 SC narrow front 16"? When were 16" wheels used? My '54 SC is still over in Michigan. Lots of questions... Thanks, Glenn F.
jal-SD
02-23-2004 07:28:20
 Re: Making sense of SC/DC part numbers in reply to Glenn FitzGerald, 02-21-2004 18:10:02
Glenn, I have a '54 SC & it has 16" cast wheels on the front. I purchased it from the 2nd owner & I'm sure they are factory original. (I've got the original owners manual.) I've visited with the previous owner several times, he knew the original owner (purchased it from the widow) & never changed the front tires while he owned it. (My $0.02 worth. jal-SD)
Glenn FitzGerald
02-22-2004 09:01:21
I must apologize...Mike Schotte responded a while back that the SC front stamped wheel and cast iron wheel both call for weight #5364A. I understand the SC could have a 16" front wheel...? Questions: 1)Can someone confirm the SC came factory with 15" or 16" front wheels, either cast iron or stamped steel? 2)Will weight #5364A work on both a 15" and 16" wheel?
John M
02-22-2004 15:59:11
 Re: Re: Making sense of SC/DC part numbers in reply to Glenn FitzGerald, 02-22-2004 09:01:21
they made two wheels that was on the tractors one looks like a car wheel that one you need a j bolt to fasten the weight the other one is all castiron wheel most of them had the castiron wheel where iam from but which one do you have the sc or dc that you want to know about hope i can help
Bruce Nelson
02-22-2004 14:58:41
My 1948 SC-3 came with 15" cast wheels. I do not see anywhere to mount weights, maybe you need to drill holes. The cast wheels weigh a bunch, seem to be their own wheel weight. Bruce
