SC brakes
Pete
02-21-2004 18:00:14
I have a 45 SC the right side brake pad bracket
is froze to the shaft. Need some ideas
on how to get off,with out damaging bracket
the brake pad goes on.
C. Amick
02-23-2004 09:21:35
 Re: SC brakes in reply to Pete, 02-21-2004 18:00:14
This is a very common problem. The lining wears out and the brake disc slides too far upon the shaft and the splines wedge. Spray some P.B Blaster inside the disc on the splined shaft. I usually wedge metal objects such as large screw drivers or flat chisels around it in several locations. I go around tapping each one in a little farther. I usually end up bending the disc a little, but it straightens pretty easily once you remove the old brake lining and rivets. I have had to use a welding torch to heat them to get them off. You will have to drain the oil down if you have to resort to this.
