A401D head Gasket Help
Woody
02-19-2004 20:21:24
Hi
I just pulled the heads off of my A401D engine. There was some coolent leaking from under the head. I got a Victor Valve grind gasket kit. Now the problem, someone who had the engine before me took the heads off and reused the gaskets. Instead of replaceing the rubber and cork O rings they used large amounts of permatex silicone on them and slapped them back together. Now I am not real sure where to put the O rings. I think the pushrod holes and the oil feed hole get o rings. I'm not sure about the water holes?
Can any one help me with this? also does anyone have any good tips on installing these heads?
Thinks
Woody
Woody
02-20-2004 11:03:47
 Re: A401D head Gasket Help in reply to Woody, 02-19-2004 20:21:24
Hi
Can someone also help me with the head bolt torque sequence?
Thank You
Woody
MGM
02-20-2004 03:05:18
There are 2 water o-rings that go just to the left and the right of the small oil hole in the block, , none go over the puch rods, the manual I have is incorrect, the other o-ring goes over the center small hole that goes up to the rocker arm shaft feed tube. Email me back if you have any more questions
Mike
