504 help needed
Ohio Case
02-18-2004 14:11:15
Ok all you case gurus..... .. What I am looking for is the case model tractors that came with the 504 motor that had the bigger valves. The motor would be used for hot farm/pro farm pulling, 3" turbo, single port water inj. 3000-4000 rpm I understand that there is a large rod bearing and a small rod bearing version. Which would work better?
Thanks for your help.
E-mail me if you want to
Dillon
02-19-2004 16:30:02
 Re: 504 help needed in reply to Ohio Case, 02-18-2004 14:11:15
The heads on a 2090 are the same as all the later heads. They are the same with or without turbo.
Jim Handke
02-20-2004 19:52:20
 Re: Re: 504 help needed in reply to Dillon, 02-19-2004 16:30:02
I've seen heads off of a 2090, and they're different from the turbo models. The intake valves are recessed deeper into the heads, and have a tendancy to crack toward the injector. They were made this way to keep you from adding a turbo and getting cheaper horses than buying a 2290.
farmall
02-19-2004 11:42:32
The 2090 heads have bigger intake valves because they were naturally asperated.
ralph smith
02-18-2004 18:45:09
I think smaller would be better because
you would have less resistance.
Thad
02-18-2004 17:07:06
The valve size i beleve is the same in all the 504s i have ever tore down. The larger journal crank would be the best in my opinion. The rod and main journals are both bigger in that engine. Anything bigger than a 1370 has the bigger crank. Hope this helps. Thad
