Case zenith carburetor
les auerbach
02-17-2004 14:56:46
The needle valve seems to get stuck and not drop down when the float lowers in the bowl. The tractor dies but in a few minutes gas runs in and it starts and runs for awhile. Is there a spring that is missing on that needle valve pin which should be there to push it down slightly. Any one have any ideas. Thanks
mj
02-19-2004 11:37:36
 Re: Case zenith carburetor in reply to les auerbach, 02-17-2004 14:56:46
Ditto on the all metal needle BUT sometimes I've had to replace both the needle and seat to get one working.
Casenut
02-17-2004 16:23:20
I have had problems with the needles with the viton tip sticking. I like to use the solid metal needles. Have not had any problems with them.
Mike Schotte
02-17-2004 15:25:59
You didn't say what model you've got- but I've had problems with the needle sticking in the seat on my Case SC carburetor, too.
Depending on whose rebuild kit you buy- the needle supplied either has a spring clip or it is a smooth needle without the provision for the clip.
When I consistently had problems with a brand new needle sticking in a freshly rebuilt carburetor- I promptly threw the non-clip needle and seat away... and will only install the kind with a clip now.
-Schotte
