1951 Case VAC
Art
02-17-2004 06:40:29
S/N VAC5572783....I bought it on Sunday In poor shape, but it still runs. Has an Eagle hitch, but missing the front mounted pump that goes to it....I guess I'll have to find another. Anybody out there that have one that they don't need? Also it has a car raditator in it, and the grill is in pretty poor shape...It started and ran in sub 0 temps on sun, so that says something.....
C. Amick
02-17-2004 14:41:07
 Re: 1951 Case VAC in reply to Art, 02-17-2004 06:40:29
If it starts and runs in zero temperatures, that just means it is a typical Case tractor. Grills are easy to find and the ones I've seen on Ebay from time to time went cheap. You should also be able to pick up a used radiator without much trouble.
mj
02-17-2004 10:09:27
Try to find the original pump if you can as they're not cheap on the used parts market ($200.00 + or -) and a new drive gear alone from CASE was about $300 last time I checked locally. Maybe the seller has it stuck under his workbench or...??? You can rebuild it if you find it.
Art
02-17-2004 06:49:27
The guy also had a real nice round nose 300, but not for sale....Maybe one day.....
