How do you find #1 cylinder compression stroke on a diesel engine?
Ed
06-29-1999 23:30:02
Ok I am trying to reinstall my diesel injection pump....& I am supposed to have the #1 cylinder on the compression stroke....how do you know it is on the compression stroke & not 180 degrees off???
Ron
06-30-1999 06:20:09
 Re: how do you find #1 cylinder compression stroke on a diesel engine? in reply to Ed, 06-29-1999 23:30:02
Watch the action of the valves as you turn the engine. When the cylinder is coming up and both valves are closed, that is the compression stroke.
It's the same as a gas engine. 4 cycle engine theory is the same for gas or diesel.
Ed
06-30-1999 22:37:05
 Re: Re: how do you find #1 cylinder compression stroke on a diesel engine? in reply to Ron , 06-30-1999 06:20:09
Thanks for the info Ron....I should have been able to figure that one out myself....
