Case VAC cultivator
Ryan
02-16-2004 20:28:40
I have a two row culivator that mounts to the front of my 1951 case vac this would be one set on each side. I was wondering how much it was worth. I am thinking everything is there. It has 2 bars that mount to the three point hitch to lift. I am thinking about selling it. Any feed back would be great.
Thanks Ryan
Franks VAC
02-20-2004 19:29:52
 Re: Case VAC cultivator in reply to Ryan, 02-16-2004 20:28:40
I have a 52 VAC like you are talking about and Have the Locators @ 45 degrees to fit the single front wheel style. If you need pictures let me know.
Ryan
02-17-2004 19:33:22
The cutivator is for a tractor with a square mount parallel to the ground so if you were looking at the tractor it would look square. My tractor has a 45 degree like a diamond. I am not sure if the tractor front end was changed or if the cultivator was off another VAC. I never seen them mounted on it. It looked to me that the square tube on the cultivator would have to be altered 45 degrees which is possible. Ryan from Minnesota
Les...fortunate
02-17-2004 02:59:15
Where were you a couple years ago when I was looking for just such an item?
Does your tractor have the holes for the cultivators that are parallel with the ground or 45o angle to the ground?
F-I-T
02-17-2004 07:03:21
 Re: Re: Case VAC cultivator in reply to Les...fortunate, 02-17-2004 02:59:15
Ryan:
Depending on your location and asking price, I'd be interested if they would fit on my '50 VAC.
Frank-in-Tallahassee
[email protected]
Ryan
02-17-2004 03:45:24
The tractor is 45 degrees the cultivator is parallel. I am not sure how that works. Someone might have changed something.
Ryan
Les
02-17-2004 15:26:21
 Re: Re: Re: Case VAC cultivator in reply to Ryan, 02-17-2004 03:45:24
I'm not sure what you mean. I'm talking about the hole in the front where the cultivators mount. Most of them are square with the ground. Mine are at a 45o angle.
Any chance you can post a picture? Where are you located? Sounds like at least two of us might well be interested. If I was to own them, I would use them, not necessarily restore them.
