Case Motor ID
Illini Case
02-16-2004 17:27:40
How on God's earth are you supposed to determine whether an engine is a 124 cu in, a 148 cu in, a 188 cu in, or a 201 cu in. I have 2 motors both have tags, one is stamped g188 (thus 188 cu in). The other is not stamped and several donor motors that people have contacted me about are not stamped. My bad block that is not stamped on the ID tag does have a casting # of G173(supposed to be a g148 in a '69 case 430). Is there a rhyme or reason to the casting codes used on case blocks that will help me identify the size of the motor, or is there any other tell tale sign that I can use for a positive ID on motor size?
Thanks
M Bush
