VAC Project: How big a plow...
F-I-T
02-16-2004 14:19:43
I'd like to find a plow to use with my VAC on light projects, you know, gardens and such. Back in Ohio, our '48 pulled a 2-12" mounted Case unit. I'd like to find one correct for my Eagle Hitch '50, but I'm thinking I'm going to have to settle for another brand.
Now, understanding that First Gear is just fine with me, and I don't need to break any speed records, AND, I don't want to install any liquid ballast, do you think that tractor would handle a 2-16" plow in sandy soil?
Just looking for recommendations OR to buy a plow nearby that would be a good fit.
Thanks!
Frank-in-Tallahassee/Pasadena
Jim
02-17-2004 18:46:01
 Re: VAC Project: How big a plow... in reply to F-I-T, 02-16-2004 14:19:43
Well, with 4 wheel weights on the back and dry tires, I can pull 2-16 or 3-12's with a VAC-14. My DC-3 pulls 3-16's in clay in southern Wisconsin
cb
02-17-2004 07:28:18
We used to farm with VAC's The later models would pull better that the early models, but lot depends on the condition of the tractor. Loaded tires will help. We used to pull 2-14's in clay.
We had a VAC-14 that if the dirt was nice would just play with 2-14's and acted like she wanted 3-14's. (we never tried)
Sometimes it better to go a little faster with smaller plow than go slow with a big one... It more fun to drive that way anyway...
GeoMo
02-17-2004 06:15:22
I have 3-point 2-12's.
I can pull everywhere in 3rd. Slip into 4th by mistake in red clay and my VAC was goint to pull.
I have pulled 2-14 ford 3-point, I think that would be largest I would go.
F-I-T
02-16-2004 20:58:19
Well, I guess I'll continue to look around and pass on the 2-16's, although our ground is very sandy!
Thanks for the ideas.
Frank
Glenn FizGerald
02-16-2004 18:13:24
DC 2 14's, MAYBE 2 16's. 2 12's=a handful for a VAC here in Green Bay, Wisconsin. Glenn F.
dctom
02-16-2004 18:13:04
FRANK TWO 14'S MOUNTED WOULD BE PERFECT FOR YOUR VAC TO PLOW GARDENS MOST ANY 3 POINT WILL WORK
Josh
02-16-2004 17:33:01
Here the ground is a little heavier, and 1-16" bottom in 2nd gear is a good match. I think 2-16" is a lot even for an SC.
Wheat Straw
02-16-2004 17:23:22
Frank,
Our ground is generaly a little tight and we pulled 2 14 in second gear but Dad had put a Super power Kit in from tractor supply so it was "souped up" at the time. I'd think 2 16 would be a load. Don't remember if you had cast weights for the rear. Shop around and you ought to be able to find what you need. course it's about time to plant your corn down there huh?
Have a great Day.
Wheat Straw
C. Amick
02-16-2004 15:11:45
We have sandy-loam here in WV. I have a set of Case 2-12" trail type plows for the VAC. I wouldn't want to pull any more than these. If you have to pull in 1st. gear, you won't do as good a job plowing as in 2nd. gear(speed helps a little). My second choice would be a set of IH plows. Some of the other plow brands just won't turn the soil very well.
